UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
Pylesw
Nov 22, 2018Tutor
It appears the problem is related to Disney Circle being enabled. Logging into the router from the Wifi side continually prompts for a password on every screen. I believe that's a symptom of the problem. Turning off Disney Circle seems to fix it without needing a reboot of the router.
pdawg17
Nov 22, 2018Guide
Circle was the problem for me too. Had tons of DNS timeouts. As soon as I disabled it everything has been great...
