UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
Feb 26, 2019Guru - Experienced User
Some users have posted about either doing a factory reset and setup from scratch after the autoupdate completes or manually loading v210 FW files first, then factory reset and setup from scratch. This has solved many users problems. Something to try upon next upgrade.
vcuser1 wrote:
Thanks. Think I figured it out. Reading through the whole unfiltered dump of 'nvram show' I found another setting 'orbi_auto_upg=1' (note the missing suffix in the name). Switching this to 0 did te trick. I'm not sure whether 'orbi_auto_upgrade' is something else or was created by me when I followed Butche's instructions where he has it as 'orbi_auto_upgrade' rather than 'orbi_auto_upg'.
Anyways, setting 'orbi_auto_upg=0' prevented it from auto-updating and now it shows f/w update button in the html admin portal and in Orbi apps telling there is newer f/w but not automatically installing it.
I'll see how 2.1.4.16 compares to 2.2.1.210 in the long run.
MikeBainter
Mar 10, 2019Initiate
FYI I have a RBR20 and one RBS20 network that worked great for about a week. Then the reported drop outs started. I’ve tried pretty much all the workarounds with no real difference. Even unplugged the satellite for awhile. Realized that a firmware update was probably the only real fix. Waited several months and today I found and had to manually download and install 2.3.0.28 (didn’t show up in the admin GUI for available firmware updates ) and it seems like it’s working okay. Time will tell and I’ll report back one way or another. Thanks everyone for the data collection!
- DickDukeMar 21, 2019Apprentice
RBK30 system plus two RBS20 satellites all updated (manually) to 2.3.0.28 this morning. So far, everything is working extremely well, does seem more stable.
- FURRYe38Mar 22, 2019Guru - Experienced User
Glad it's working well. I would do a backup configuration to file for safe keeping in case you need to factory reset later on. Saves time.
Enjoy. :smileywink:
