UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
DickDuke
Mar 22, 2019Apprentice
RBK30 system plus two RBS20 satellites all updated (manually) to 2.3.0.28 this morning. So far, everything is working extremely well, does seem more stable.
Mar 22, 2019Guru - Experienced User
Glad it's working well. I would do a backup configuration to file for safe keeping in case you need to factory reset later on. Saves time.
Enjoy. :smileywink:
