RedSunofNW
Mar 14, 2020Follower
Way to prevent VPN/Proxy bypass Meet Circle
We know the function “Not Allowed" VPN/Proxy is a gimmick. The Orbi apps shows few devices connect to WIFI router. The meet circle also shows sites these devices visited. Whenever we pause the device from device lists in Circle apps. The history still shows visited sites in history log as no pause of WIFI access at all. The VPN/Proxy uses to circumvent any restriction on WIFI router.
We need to block service the only solution I need to apply to the Orbi Mesh is closed all router PORT used by VPN, Proxy, SSH, IPsec…
Here is the list of ports you may consider blocking access depend on your need.
HTTPS (TLS/SSL) – 443 UDP
HTTP – 80 UDP
OpenVPN – 1194 TCP/UDP
PPTP – 1723 TCP/UDP
L2TP – 1701 UDP
SSTP – 443 UDP
Cisco IPsec – 1293 TCP/UDP, 500 TCP/UDP
IPsec/IKEv2 (Internet Key Exchange) – 500 TCP/UDP
IPsec Nat Traversal – 4500 UDP
SSH tunnel – port 22
SOCKS proxy – 1080 TCP
BitTorrent – 6881-6889 TCP
SMTP – 25 TCP/UDP
DNS – 53 UDP
1 Reply
An interesting post, but perhaps some context would help. It appears that this in reference to some feature of Disney Circle? (that doesn't work?)
