index4u's avatar
index4u
WDNR4300v2 One device displays twice in the Network Map
My Genie's network map shows the same device, a TiVo Roamio Pro, twice. In each detail display, only the IP Address varies. One of the addresses matches the one displayed in the Roamio's network sett...
  • st_shaw's avatar
    st_shaw
    Jun 13, 2017
    Ok.  Some TIVOs have built-in WiFi.  If the TIVO WiFi is associated with Orbi and you have it wired as well, you would get two different IPs.
