index4u
Jun 12, 2017Aspirant
WDNR4300v2 One device displays twice in the Network Map
My Genie's network map shows the same device, a TiVo Roamio Pro, twice. In each detail display, only the IP Address varies. One of the addresses matches the one displayed in the Roamio's network sett...
- Jun 13, 2017
Ok. Some TIVOs have built-in WiFi. If the TIVO WiFi is associated with Orbi and you have it wired as well, you would get two different IPs.
index4u
Jun 13, 2017Aspirant
I power cycled both the router and the TiVo. For a few minutes, only one instance of the TiVo appeared in the network map, but then the second instance reappeared.
st_shaw
Jun 13, 2017Master
