Dustin_V
May 08, 2018NETGEAR Employee Retired
We Squeezed a Cable Modem under-the-hood of the new Cable Modem Orbi WiFi System!
Say goodbye to equipment rental fees and hello to ultra-fast WiFi coverage for your whole home! Orbi Whole Home WiFi with Built-in Cable Modem is the industry’s first Cable Modem Router WiFi Syst...
RocketSquirrel
May 11, 2018Luminary
brh wrote:
I just purchased the RBK40 system with 2 satellites and a CM600 Modem. If I purchase this new product what happens to the router in my RBK system? Can it be used as another satellite? I realize that the CM600 modem will no longer be needed. Will the new combo be better than what I already have?
Brian
Since no one more authoritative has replied, I’ll chime in.
Replacing one DOCSIS 3.0 modem with another won’t be an upgrade. My ISP, Comcast, emailed me saying “We see you’re still using a DOCSIS 3.0 modem. You should upgrade to 3.1.” So I did. Comcast is actually providing 3.1 now.
Unless you’re seriously short on space or electrical outlets, I see no advantage to a combined modem/router. Keeping them separate provides more flexibility when you need to upgrade. If you buy the combo unit, you’ll need to put your existing Orbi router into Access Point mode. It will not work as a satellite.
brh
May 11, 2018Master
Thanks for your answer. I am with Spectrum and last month I upgraded to their 400mbs/sec plan. I then purchased the Orbi RBK system and added another satellite. I wasn't sure if the Arris modem they rented me was good or not but on their website the Netgear CM600 was what they said would work with this speed. Turns out the Netgear router does not seem to be any better than the Arris, but now I no longer need to rent a modem from them. I am just trying to eek out as much speed as i can for what I am paying for and I just saw this today and was curious about it.
Thanks again for your reply.
Brian
