Retired_Member
Jan 02, 2017Weak WiFi Security - being warned by several app of unauthenticated certificate risk
I would not recommend this product due to its weak security features. While it gives strong WiFi signals but weak security has stopped me from using the product for serious business use. Take for exa...
Mikey94025
Jan 02, 2017Hero
Can you post a picture and identify what applications prompt you for unauthenticated certificates? This likely has nothing to do with the router and is something on your end.
Ely
Jan 03, 2017Luminary
Sorry but your router has nothing to do with "Anauthenticated Certificates" something else is going on here.
