kmg365
Jul 06, 2020Follower
Weak Wifi Signal in new detached garage
I am considering purchasing the Orbi WiFi Range Extender RBS50Y and wanted to know if this is has heloed anyone with their WiFi signal in a detached garage with metal walls. My garage is about 30" fr...
CrimpOn
Jul 06, 2020Guru - Experienced User
kmg365 wrote:I am considering purchasing the Orbi WiFi Range Extender RBS50Y and wanted to know if this is has helped anyone with their WiFi signal in a detached garage with metal walls. My garage is about 30" from the house and 80' from the router. I have a decent signal outside the garage but once I go inside I lose signal.
Looking for recommendations.
Metal walls will severely impede WiFi signals and 80 ft. is a considerable distance taking walls and obstacles into account. There's probably not a window on the side of the garage facing the house?
