GKACK
Oct 17, 2021Tutor
Web interface shows inactive device as active- App also shows inactive devices
A few months ago, what appears to be a Bose 1 SoundTouch was connected to our Orbi system by a houseguest. That device is no longer in the home yet this device still shows on the Attached Devices li...
Oct 18, 2021Guru - Experienced User
GKACK
Oct 18, 2021Tutor
I have not done a factory reset but I did delete and reinstall the phone app. Would a factory reset retain the firmware or does that get reinstalled? Would I be able to save my configuration and easily get the system back up and running or would that defeat the purpose?
- FURRYe38Oct 18, 2021Guru - Experienced User
It retains.
Try either loading from saved back up and see after the reset and see if problem continues. If it does, you'll need to try a reset with out the back up config file.
