jeraboom
Oct 13, 2020Star
Web UI says RBW30 Update Failed, but there is no update available.
I have a system with an RBR50, 2 RBS50s, and 1 RBW30. When I use the router Web UI to check for firmware updates, it first attempts to download new firmware for the RBW30 and then says "Update Faile...
- Oct 20, 2020
RBW30 latest firmware v2.6.1.6 has been posted on the Support Site. Here's the link:
https://kb.netgear.com/000062471/RBW30-Firmware-Version-2-6-1-6
Blanca
Community Team
Mstrbig
Oct 13, 2020Master
jeraboom wrote:I have a system with an RBR50, 2 RBS50s, and 1 RBW30.
When I use the router Web UI to check for firmware updates, it first attempts to download new firmware for the RBW30 and then says "Update Failed".
When I manually download the current RBW30 firmware from Netgear and go directly to the RBW30 and attempt to update the firmware, the UI there says it's already running the current version. (see attached screenshots)
Side note: I see there's an even newer version of the RBR50/RBS50 firmware (2.7.0.70), but it's not being offered to me via the Web UI update function.
Version 2.7.0.70 is actully the newest firmware available for the RBR50 router and RBS50 satellite. You would have to manually download it and install it. If you decide to update, make sure you update the satellites first, then the router.
- TgtermOct 16, 2020Guide
Exact same configuration and issue with the RBW30 Update Failed here. I was able to update my RBR50 and RBS50 by unplugging my RBW30, but has there been a resolution to the Update Failed issue on that satellite yet? Or, is Firmware 2.5.0.4 for the RBW30 the latest, therefore nothing to fix? Thanks!
Online UpdateManual UpdateFirmware UpdateCheck if a new firmware version is available on the Internet. Model Name Device Name Current Version Status Router RBR50 RBR50 V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Kitchen V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Upstairs V2.5.2.4 No new firmware version available. Satellite RBW30 RBW30 - Basement V2.5.0.4 Update failed - FURRYe38Oct 16, 2020Guru - Experienced User
V4 is the latest for the RBW. No need for any update. I presume the update services are incorrectly reporting this for the RBW. Should be No Update Available. Maybe a forum moderator and check on this.
Tgterm wrote:Exact same configuration and issue with the RBW30 Update Failed here. I was able to update my RBR50 and RBS50 by unplugging my RBW30, but has there been a resolution to the Update Failed issue on that satellite yet? Or, is Firmware 2.5.0.4 for the RBW30 the latest, therefore nothing to fix? Thanks!
Online UpdateManual UpdateFirmware UpdateCheck if a new firmware version is available on the Internet. Model Name Device Name Current Version Status Router RBR50 RBR50 V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Kitchen V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Upstairs V2.5.2.4 No new firmware version available. Satellite RBW30 RBW30 - Basement V2.5.0.4 Update failed - TgtermOct 16, 2020Guide
Thank you very much for confirming. Would be nice if Netgear fixed this, though. Makes updating the firmware on the router and other sats a bit of a PITA.
Thanks!
- Blanca_OOct 20, 2020NETGEAR Employee Retired
Blanca
Community Team- TgtermOct 21, 2020Guide
Update still fails when I try to perform an automatic update through the router UI. Can you please remind me of the method to update the RBW30 manually, if that is what you are saying we need to do?
Thank you.
