jeraboom
Oct 13, 2020Star
Web UI says RBW30 Update Failed, but there is no update available.
I have a system with an RBR50, 2 RBS50s, and 1 RBW30. When I use the router Web UI to check for firmware updates, it first attempts to download new firmware for the RBW30 and then says "Update Faile...
- Oct 20, 2020
RBW30 latest firmware v2.6.1.6 has been posted on the Support Site. Here's the link:
https://kb.netgear.com/000062471/RBW30-Firmware-Version-2-6-1-6
Blanca
Community Team
Blanca_O
Oct 20, 2020NETGEAR Employee Retired
Blanca
Community Team
Tgterm
Oct 21, 2020Guide
Update still fails when I try to perform an automatic update through the router UI. Can you please remind me of the method to update the RBW30 manually, if that is what you are saying we need to do?
Thank you.
- FURRYe38Oct 21, 2020Guru - Experienced User
Do you have access to the RBWs web page? Look for the IP address on the RBRs connected devices page. Use the IP address given to the RBW to access it's web page. Log in will be same as RBR.
- TgtermOct 21, 2020Guide
good thought, except the RBW30 does not accept the password I use to gain access to my RBR50. I even try the default password, and no joy. One hurdle after another. Any thoughts on how to reset the RBW30 password or why it does not accept the password from my RBR50?
Thanks!
Check the user manual for password defaults...
Try a factory reset with the RBW and re-sync it to see if it will connect and the the admin and PW from the RBS50...I believe it should
So, I have reset it and resynced it multiple times, still will not accept the RBR50 login credentials. I am a little skeptical of the reset, tbh. When the RBW shows up in my connected devices again, it still shows up with the label 'RBW30-Basement'...something I had renamed it to. If it were a true reset, shouldn't it lose that label?
Not sure what to do at this point. Can't get firmware update access to my RBW30...
Did you remove it from the RBR after resetting it?
Ya, the reset should clear things however if it resynce with the RBR the RBR may hand off the same config again...
