ScottWay
Jan 28, 2020Aspirant
Webcam streaming issues
I am having issues with streaming webcams from a university campus. These stream perfectly from every location I visit with my computers and phones: coffee shops, work place, other peoples homes. Th...
- Feb 02, 2020
I think its *FIXED*!! Thanks to everyone for the advise and support.
I had unplugged and cycled my Spectrum modem many times. Today I decided to RESET it. Well, that did the trick. It seems crazy to me but that was it. How very odd.
Thanks again to everyone in the NG support pages!
CrimpOn
Jan 28, 2020Guru - Experienced User
ScottWay wrote:I am having issues with streaming webcams from a university campus.
However, none of my devices will stream these cams at home on my wifi using my Orbi. I have disabled all parental controls.
LOVE the campus webcams. (They stream fine on my Orbi RBR50.) Would it be OK to ask which web browser is being used to stream these cams? (on which platforms?)
I would be sort of shocked to think that Disney Circle could ever find these streams objectionable.
As FURRYe38 pointed out, that particular firmware has been "disgraced" and users are encouraged to update to 2.5.1.8. I sincerely doubt that the Orbi firmware is the cause of this specific problem, but there is no sense remaining on firmware with "known issues" of any kind.
Could you explain more about "what happens" when you attempt to stream these feeds?
ScottWay
Yes the cams are great. I watch my son play broomball.
I use Chromium Edge browser on win10. Chrome on Android. I have Circle disabled.
- ScottWayJan 28, 2020AspirantForgot to mention..the adobe module loads and the stream tries to start but just circles. Never loads and times out.
- CrimpOnJan 28, 2020Guru - Experienced User
My first step would be to try another browser, Firefox or Opera.
- ScottWayJan 31, 2020Aspirant
Well, the router and satellite upgrades went well. Unfortunately the webcams of interest still do not work. As I mentioned a) they work as soon as I switch to cellular b) I get same results in multiple browsers and c) works fine if I connect to other wifi (work, coffee shop, neighbor). Strange.
