Brenkj
Feb 17, 2019Aspirant
Website(s) blocked
I installed my Orbi system Friday. Since then when I try to navigate to CNN.com, I get a weird-looking page that asks for my password (I don’t have a pw for CNN). I’ve gotten a similar page for a coup...
Brenkj
Thanks for your continued help. I can't access the Orbi login site because of the problem I'm trying to fix (I get the same "password" screen I get for other sites). Would the be a difference in how my overall network operates if I manage to get the AP mode enabled?
ekhalil
Feb 17, 2019Master
Brenkj wrote:
Thanks for your continued help. I can't access the Orbi login site because of the problem I'm trying to fix (I get the same "password" screen I get for other sites). ......
Please do as follows:
- Check which IP address range your devices that are attached to Orbi are getting. See if they have address starting with 192.168.1.x or 10.0.0.x
- Disconnect the ISP router from the WAN port of Orbi by pulling out the LAN cable.
- From a computer attached to Orbi (wired or wireless) use a browser to navigate to the IP address of Orbi which -most likely- is 192.168.1.1 or 10.0.0.1, depending on the IP range you find our in step 1 above.
- Use the steps in the previous post to set Orbi to AP Mode
Brenkj wrote:
........ Would the be a difference in how my overall network operates if I manage to get the AP mode enabled?
There are certain router functionality like DDNS, VPN, Parental Control, ..... which only a router can provide, so choosing Orbi or the ISP router to be your router will also decide which router will provide you with those features.
- BrenkjFeb 20, 2019Aspirant
I really appreciate the responses, but as a non-technical person this is more than I want to mess with. I'm going to return the refurbished Orbi system and maybe get a new system once I find someone local who can figure out how to properly put my modem into bridge mode.
