jbintn's avatar
jbintn
Weird behavior with RBR50 Dropping Speed
I have the RBR50 router and 1 RBS50 satellite. My ISP (EPB in Chattanooga) plan is for 1 GB up/down. Most of the time when I do a speed test (using the Orbi app, so the test is directly from the router) I get ~910-920 Mbps. I'm fine with that. The problem is that a few times a day, I notice some lag and connectivity issues. When I use the Orbi app on my phone to do a speed test, it now reports ~90 Mbps, which is quite a drop. Rebooting the router has no effect. Every time, guaranteed, what does fix it is if I unplug the cable from the back of the router and right back in. (This is the cable coming from the wall - it's fiber, so there's no modem - but I only unplug the router end.) After doing that the speed test immediately jumps back up to about ~900 Mbps. Every time.
I've tried two different cables (both are Cat-5e, which should be fine), and both have the same result: unplug from the back of the router and right back in, and my speed immediately jumps to what I'd expect.
My RBR50 and RBS50 were on 2.7.4.x, and just got updated tonight to 2.7.5.4. I'm hoping that fixes the issue, but we'll see.
Anyone seen any issues like this or have an explanation?
