CynDaVaz
Nov 08, 2017Tutor
Weird issue with my Orbi
Back in the summer, when I first set up my Orbi to work with my Nighthawk AC1900/C7000, I disabled the router function in my Nighthawk and set the Orbi as my router. That original discussion can be f...
RogerSC
Nov 09, 2017Virtuoso
The way that I read your original thread is that you ended up with the Orbi in AP mode, connected to the modem/router which has it's wireless turned off. In other words, what you're seeing now is exactly the way that you ended up setting it up according to the original thread. So don't worry, be happy, just continue to use it as you have it set up now. This is, by the way, the same way that my router and Orbi are set up. The R7800 is in router mode, set up to do the routing functions (routing, NAT, DHCP) with it's wireless radios turned off. And my Orbi is in AP mode, and it all works simply marvelously *smile*.
Everything is as it should be, as you set it up. Enjoy!
CynDaVaz
Nov 09, 2017Tutor
DERP! You're right. That's exactly what I did. Good grief. I should have re-read that original thread in its entirety; I just skimmed over it to refresh my memory and paid more attention to the part about disabling the radio on my Nighthawk, so I assumed I'd also disabled the router function.
So it seems the satellite issue is not caused by what I mentioned here. Then I wonder what on earth could be the problem. This is why I wish the Orbi was a true mesh system. I think the satellite that's having issues would work much better. *sigh*
- RogerSCNov 09, 2017Virtuoso
I was having an intermittent problem with my satellite for a few days. Turned out that moving the satellite about 10 or 15 feet closer to the router stabilized it. The odd thing was that the router and the satellite both indicated that they were well connected to each other in their web admin interfaces when I looked. I'm attributing this to the variability of wireless, that at the points when the wireless backhaul network cycled to it's lowest points, that the satellite lost the solid connection that it needs and went unstable. The wireless never went down completely since the router unit stayed up, but the satellite would cycle from connected (blue) to isolated (magenta). It would fix itself for a while when I power-cycled the satellite, but then some time later the satellite would go crazy again.
At any rate, the satellite has been fine since I moved it closer to the router. And I still have the same great wireless coverage.
- CynDaVazNov 09, 2017Tutor
I tried moving it too - about the same amount as you did but that didn't seem to help. When I brought it into the same room as the Orbi router, it seemed to work fine. But it had been working fine for months where I'd put it the first time. And then it decided that it wouldn't work so well anymore there. :/ I had been using it with a Roku directly plugged in.
