eljarviso
Jan 08, 2020Luminary
Weird slow speed issue after loss of gateway connectivity
Here’s a weird one. I’m running the latest 2.5.1.8 firmware. Rbr50 is running in AP mode with WAN uplink going to a managed switch. Switch is connected to an Ubiquiti ER-X router. Router connects dir...
- Feb 03, 2020
Hi Bianca,.
I've tried this with a Trendnet TPE-1620WS and a Cisco catalyst 3750G using IP Base licensing.
The problem seems to have disappeared after installing Voxel's third party firmware.
eljarviso
Feb 03, 2020Luminary
can't use an unmanaged switch as there are devices in my environment that require lacp trunks and vlans.
I don't require IGMP snooping or anything so those features are disabled.
Feb 03, 2020Guru - Experienced User
Ok, If IGMP was disabled stock FW should work however sometimes see odd issues with mangaged switches...sometimes.
Glad Voxels FW solve it. Mark your post thread as solved.
Enjoy.
