MyOrbiGear
Feb 10, 2018Initiate
What’s with all the buffering?
I switched to the Orbi and got great results on internet speeds, almost double what i was receiving before, but I am also plagued with 4 times the buffering delays. I also have a shorter frequency len...
JoeCymru
Feb 11, 2018Virtuoso
Too many unknown variables to give you any kind of good answer. Do you live in a building or detached home? Are you trying to send signal through concrete and rebar? Did you test the router and satellite in a different configuration such as a test with them separated by about 30 feet with a reasonable clear line? Did you check on the GUI to see the condition of the backhaul? Did you check on attached devices to see how they were hooking up if at all? What is going on with the indicator rings when you install them? Have you downloaded the WiFi analyzer app (iOS or Android) to see what is happening to you signal strength when you move aroun (below -68db is practically worthless for streaming).
