Retired_Member
May 13, 2020What ‘Administration Password’ Special Characters can I have?
For security reasons, I like to have a Password’ of over 30 random Characters including Special Characters, numbers & upper & lower case letters. I try to change my ‘Administration Password’ for ...
May 13, 2020Guru - Experienced User
Not sure if this applies to Orbi systems:
Something to ask NG support about though...
CrimpOn
FURRYe38 wrote:Not sure if this applies to Orbi systems:
I am definitely certain that this does not apply to Orbi systems. At the most, it is a recommendation that a "strong password" should be at least 8 characters long and have at least one of Upper, Lower, Numeric, and Special characters. More than one character from each group is clearly allowed. The question is which special characters are allowed (or conversely, which are not allowed).
This calls out for an experiment.
- FURRYe38May 13, 2020Guru - Experienced User
Ya I use a simpler PW for my needs thus I haven't tried any special characters.
Please let us know what you find out Sir. :smileywink:
- Retired_MemberMay 13, 2020
Thank you for those people who reply to my question. I will just have to experiment to see what’s acceptable. I did experiment a long time ago, but I forgot what I did.
I hope the people who do the Orbi updates, put a clear message on the ‘Administration Password’ page.
Before we put anything in the password field stating the minimum & maximin number of Characters?
Also, the Characters which is acceptable & those that are not acceptable? Thanks.
- CrimpOnMay 13, 2020Guru - Experienced User
I can report on a simple experiment testing which "special characters" may be used in Orbi web interface administrative password. "All of them on the keyboard."
I created a base bassword "T3sting" (which will keep Orbi from complaining about it not being "secure enough") and added a special character to the end. Each change required me to authenticate again, which was accepted. I then used that "old" password and entered the next on the list as "new", and repeated the process. Apply, authenticate, enter old, new...
Here is the list I used, starting with period and ending with question mark. I marked each password that was accepted "OK".
T3sting. OK
T3sting, OK
T3sting/ OK
T3sting! OK
T3sting@ OK
T3sting# OK
T3sting$ OK
T3sting% OK
T3sting^ OK
T3sting& OK
T3sting* OK
T3sting( OK
T3sting) OK
T3sting_ OK
T3sting+ OK
T3sting~ OK
T3sting` OK
T3sting{ OK
T3sting} OK
T3sting| OK
T3sting[ OK
T3sting] OK
T3sting\ OK
T3sting: OK
T3sting" OK
T3sting; OK
T3sting' OK
T3sting< OK
T3sting> OK
T3sting? OKI did not use Escape, backspace, tab, enter or any of the "really special" characters created by using a combination of ""Alt"+number.
So, I am unable to reproduce the problem. Maybe some combination of two consequitive special characters "does something"? Since this is a Linux system, somehow entering a "null" character would terminate the string.
This leaves me mystified. Sorry.
