Supergate
Apr 26, 2019Aspirant
What are the Correct settings for optimal usage for Orbi Router w/ 3 Sats
I have a RBR50 and 3 satelites hooked up in my house. We have the Nest cameras and a doorbell and Alexas and various other WiFi devices. What is the best settings to use on the router to get optimal ...
Apr 26, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using? WPA2 and AES only.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Supergate wrote:
I have a RBR50 and 3 satelites hooked up in my house. We have the Nest cameras and a doorbell and Alexas and various other WiFi devices. What is the best settings to use on the router to get optimal reliability? Whats the best for multiple users that stream and game. I have full signal in the entire house and I still keep getting disconnects and unstable connections. What should I do?
Supergate
Currently I have an ARRIS - SURFboard 8 x 4 DOCSIS 3.0 Cable Modem.
The firmware on router is V2.3.1.48.
The house is about 4000sq ft
The distance between router and sats are under 30ft.
We have about 3 to 4 neighbors with WiFi. The channels are on auto and its on WPA2.
Daisy chain is disabled along with 20/40Mhz.
- FURRYe38Apr 26, 2019Guru - Experienced User
There a model # for the modem?
I would set the sats to at least 30 feet. Any thing under maybe too close....
Try manual channels
- gr8shoApr 27, 2019VirtuosoIn the advanced section of
the mgmt console, I run the three wireless options on the bottom of the screen set to on. They are off by default.
Daisychain off only works for you if devices arranged as hub and spoke.
Find a way to run WiFi analyzer on an Android phone or tablet and use it to pick the best channel.
Short of all that, next thing to try is a full on factory reset.
