Cmo1
May 26, 2018Apprentice
What are the most efficient settings for me to use?
I have recently purchased an orbi to replace my apple airport extreme that I was using due to the fact I needed an extended network in my home after adding a Ring 2 doorbell. I had an airport extrem...
May 26, 2018Guru - Experienced User
I would try using manual channels 1, 6 or 11 on 2.4Ghz.
Firewall features should be enabled for safety and security.
You can disable Daisy Chain and MIMO. Leaving Beamforming enabled.
Besure to not enable the onboard speedtest app, Traffic Meter or Access Controls as this will reduce the 1Gb speed service.
If you notice issues with 2.4Ghz at the lower power level, i would turn it back up to 100%.
Yes starting detance should be 30feet between router and satellite(s).
I have the Orbi router and 1 satellite in a 5000sq ft home and works well at 40 feet in between.
- Cmo1May 26, 2018Apprentice
Should I change rts/cts threshold or doesbn't that matter at all? I have definitely avoided the speedtest, access controls as well..told that would be bad
- FURRYe38May 26, 2018Guru - Experienced User
Those don't need any change. Unless your having wifi connections issues with client device, id leave them as default.
