Cmo1
May 26, 2018Apprentice
What are the most efficient settings for me to use?
I have recently purchased an orbi to replace my apple airport extreme that I was using due to the fact I needed an extended network in my home after adding a Ring 2 doorbell. I had an airport extrem...
Cmo1
Should I change rts/cts threshold or doesbn't that matter at all? I have definitely avoided the speedtest, access controls as well..told that would be bad
FURRYe38 wrote:
I would try using manual channels 1, 6 or 11 on 2.4Ghz.
Firewall features should be enabled for safety and security.
You can disable Daisy Chain and MIMO. Leaving Beamforming enabled.
If you notice issues with 2.4Ghz at the lower power level, i would turn it back up to 100%.
Yes starting detance should be 30feet between router and satellite(s).
I have the Orbi router and 1 satellite in a 5000sq ft home and works well at 40 feet in between.
May 26, 2018Guru - Experienced User
Those don't need any change. Unless your having wifi connections issues with client device, id leave them as default.
- Cmo1May 26, 2018Apprentice
Also....ipv6 is disabled by default. leave it disabled? I have no need for it that I know of.
- FURRYe38May 27, 2018Guru - Experienced User
Unless you have native IPv6 support from your ISP, leave it disabled.
