jetter2
Jul 23, 2019Tutor
What Back-haul Channels are Available?
Hey gang, I just bought an RB50 pair and have 2 questions. Can I adjust the bandwidth of the backhaul channel down to say, 20MHz? If they are .11ac radios, a higher MCS on a 20MHz channel migh...
CrimpOn
Jul 23, 2019Guru - Experienced User
There is a really thorough explanation of Orbi radio channels in this post:
https://community.netgear.com/t5/Orbi/Understanding-Orbi-Radio-Fronthaul-Backhaul/m-p/1671092
jetter2
Jul 23, 2019Tutor
I haven't seen a definitive table ANYWHERE that lists the Backhaul, nor the fronthaul channels as DFS capable..
- CrimpOnJul 23, 2019Guru - Experienced User
jetter2 wrote:I haven't seen a definitive table ANYWHERE that lists the Backhaul, nor the fronthaul channels as DFS capable..
The only 5G channels the Orbi allows a user to select are 36, 40, 44, 48 which are all "not DFS" in any country. Some of the channels are forbidden in specific countries, such as Israel, China.
The list of backhaul channels the Orbi will select from probably varies by country. In the US, this is what my Orbi shows:
root@RBR50:/# iwlist ath2 freqchannel
ath2 126 channels in total; available frequencies :
Channel 100 : 5.5 GHz
Channel 104 : 5.52 GHz
Channel 108 : 5.54 GHz
Channel 112 : 5.56 GHz
Channel 116 : 5.58 GHz
Channel 120 : 5.6 GHz
Channel 124 : 5.62 GHz
Channel 128 : 5.64 GHz
Channel 132 : 5.66 GHz
Channel 136 : 5.68 GHz
Channel 140 : 5.7 GHz
Channel 149 : 5.745 GHz
Channel 153 : 5.765 GHz
Channel 157 : 5.785 GHz
Channel 161 : 5.805 GHz
Channel 165 : 5.825 GHz
Current Frequency:5.785 GHz (Channel 157)A bunch of these channels are DFS in the US. (100 through 144). As far as I know, my Orbi has never selected a DFS channel. There is a file where Orbi writes a message any time radar is detected: /var/radardetect.log I have never found this file on my Orbi.
Other community members have reported finding the file with contents. For example:
Radar Detected at [Wed Jan 23 23:19:55 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Wed Jan 23 23:26:20 CET 2019 ] on channels [100,104,108,112]- jetter2Jul 23, 2019Tutor
Yeah...I live in a pretty busy 5GHz enviornment and about the only way I can see myself actually keeping the Orbi system is if they can actually Mesh over DFS channels...
- ekhalilJul 23, 2019Master
jetter2 wrote:Yeah...I live in a pretty busy 5GHz enviornment and about the only way I can see myself actually keeping the Orbi system is if they can actually Mesh over DFS channels...
In Europe the DFS channels are 52-64 & 100-140.
My Orbi is using only DFS channels for backhaul as I can see. Almost always I see the used backhaul channels are either 108, 116, 132 or 140.
