dbriankessler
Apr 25, 2019Tutor
What do I need for better wifi?
Ok, so I have an Orbi system (Orbi micro RBR20). It has the base unit and two satellites. I have great wifi in the house. My garage is connected to my home, but not in the usual "tight under one cont...
- Apr 30, 2019
Log in to the routers web page to make changes.
CrimpOn
Apr 25, 2019Guru - Experienced User
Is the "Daisy Chain" option turned on?
The Orbi RBW30 is designed to be plugged into a wall electrical outlet, which may not have a good radio pathway to the satellite in the house. (down low, behind things like refrigerators, etc.) Have you tried connecting the RBW30 to an extension cord and placing it as close to the house as possible?
dbriankessler
Apr 30, 2019Tutor
I will have to go into the settings and look for that. I didn't know you had to turn daisy chain on. I assumed it was automatic. Thank you. I may not have time until this weekend, but I will report back with the results/findings.
