dbriankessler
Apr 25, 2019Tutor
What do I need for better wifi?
Ok, so I have an Orbi system (Orbi micro RBR20). It has the base unit and two satellites. I have great wifi in the house. My garage is connected to my home, but not in the usual "tight under one cont...
- Apr 30, 2019
Log in to the routers web page to make changes.
dbriankessler
Apr 30, 2019Tutor
I will check out the additonal settings and suggestions you have mentioned also FURRYe38. Home size is 3400 sq ft. Distances were posted but the max is about 30 feet from the base unit. Well, it's 30 feet to the first satellite and about 20 feet to the second on one side of the house. But if daisy chain isn't turned on (I didn't know you had to turn that on) that could explain why it doesnt seem to be better.
Apr 30, 2019Guru - Experienced User
Ya, it's been a contentious feature for some and depends on placement configuration for users. So NG left it up to users to figure out if they need it. Overall, it should be disabled for users with just one satellite or if multiple satellies are placed in start formation with the RBR. Linear placement with multiple satellites then Daisy Chain could be enabled.
Make sure the distances are around 30 feet. Any closer and could have too much over lap on wifi coverage which can cause problems.
- dbriankesslerApr 30, 2019TutorI forgot to ask, do I make these changes via the Orbi app or do I have to login to the router itself?
- FURRYe38Apr 30, 2019Guru - Experienced User
