BrianG_Simi
Apr 04, 2021Star
What does "Connected via Orbi" mean in my wi-fi connection & is it a problem "via Orbi" is now gone?
I was struggling with the Samsung "Couldn't Authenticate Connection" error and went through a number of different ways to remove and recreate my current wi-fi connection. At some point in the "re...
schumaku
Apr 06, 2021Guru - Experienced User
Probably is shows the network with this "via Orbi" somewhere in the Orbi App - on plain Android (or Apple iOS) only the network name (SSID) will be shown.
- BrianG_SimiApr 06, 2021StarJust to be clear, the "Connected via Orbi" was showing in the Android (Samsung One UI 3.1) wifi screen, not within the Orbi app.
I was hoping it has some significance and provides a clue to the authentication errors I was seeing. I can't seem to duplicate it. Perhaps, it's related to creating the network directly from the main router vs a satellite?- CrimpOnApr 06, 2021Guru - Experienced User
An internet search for "Samsung One UI 3.1 WiFi" turned up numerous issues with connecting to WiFi after the Samsung update.
I did not locate a post that specifically mentions the term "via", but I gave up pretty quickly.
My guess is that since this appeared on the phone, the answer lies with Samsung, not Netgear.
I'm sure the "authentication" issue is with Samsung, but that's really not my question - I think I've got the authentication issue "solved".
What I'm wondering is what the mechanism would be for my Samsung connection to be "aware" that I was connected "via Orbi". Is the router advertising itself in a way that Samsung / Android can pick up? Is this something that's just standard in the WiFi spec or something special between Samsung \ Android and Orbi? Was it somehow related to having the Orbi app installed? Most importantly, is there any downside to no longer seeing "via Orbi"?
