RocketSquirrel
Mar 30, 2019Luminary
What does this mean in the 2.3.1.44 firmware?
Release notes for .44 say
Fixes the issue where the Armor activation fails if the device is offline
What does this mean? I must have missed a memo about something called Armor.
- Mar 30, 2019NETGEAR Armor is an advanced multi-layer cyber security solution that protects not only your network but individual devices as well. NETGEAR Armor protects your devices from viruses, spyware, hackers, spam, and phishing.
This was introduced recently in Orbi, from software version 2.3.0.32.
https://www.netgear.com/landings/armor/default.aspx
ekhalil
Mar 30, 2019Master
RocketSquirrel
Thanks. I assume Armor only operates when the Orbi is in Router mode. Mine is in AP mode.
- plemansMar 30, 2019Guru - Experienced User
correct. It only works in router mode.
