Ashley71
Oct 17, 2019Aspirant
What happened to additional RBS50 - New buyer - Frustrated
Hi I bought a 2 pack RBK50 (AC3000) with the router and one RBS50 satelite included. I also bought an extra outdoor satelite RBS50Y I still have black spots, which is annoying given the ~$1,000 i'...
michaelkenward
Oct 18, 2019Guru - Experienced User
Ashley71 wrote:
I now wish to buy another RBS50 and can't seem to find them for sale other than as the outdoor model or in this pack with another router.
Where are you?
They exist in some places:
If you can't find a local supplier, you are not tied to the RBS50 for your choice of satellites.
- plemansOct 18, 2019Guru - Experienced User
michaelkenward was right in his link (for the uk). just search your area's amazon for rbs50. You might even look at the other satellites as well like the rbs40 and rbw30 if you're not needing the extra backhaul bandwidth or ethernet ports.
- Ashley71Oct 18, 2019Aspirant
Thanks for the replies and assistance!
ok, i can find them at Amazon Australia (where I am).
next majorly disappointing thing then is that to buy just a satalite is $493 ( I was expecting $250 odd) and to buy another bundle (router and satelite) costs $469. Madness. Outdoor ruggedised satelites are on sale for $399 - which would be my best overall bet. I'd buy two satelites bundled for $469, but that doesn't seemt o be an option. Netgear's product / marketing team aren't making this easy (for me at least)
I'll guess i just buy another outdoor one. More than what I wanted to spend, but i'm 2/3 pregnant now. I hope I don't need a 4th satelite :-(
- michaelkenwardOct 19, 2019Guru - Experienced User
Netgear's pricing has always been a puzzle. The RBS50 costs £169.99 here. And the pound is on the floor.
Don't forget the suggestion that you can use other Orbi satellites with your system. Something cheaper might work.
Then again, I'd consider this bit:
Careful positioning of your existing stuff might eliminate the need for another satellite.
