HTBruceM
Aug 17, 2019Guide
What happened to my posting
I posted then edited the posting with a different title and it disappeared? https://community.netgear.com/t5/Orbi/Sat-WiFi-downloads-slow-to-kilobits-s-with-wired-backhaul/td-p/1789011 I spent a lo...
- Aug 18, 2019
HTBruceM wrote:.......
I REALLY need some stability in the network because I'm planning to drop my Dish Network and switch to YouTube TV streaming service in the next month, so even TV viewing will then be dependent on internet access. Technically I don't even really need a mesh system because I've got the CAT6 wiring I need to just use APs. Whatever; this is where I am right now.
I have a very stable and robust wifi network currently with 2.3.5.30. All I needed to do related to wired backhaul is mentioned in this post: https://community.netgear.com/t5/Orbi/Wired-Backhaul-in-recent-firmware-releases/m-p/1783871#M67538
This should not e difficult to do to fix your issues and improve your system.
HTBruceM
Aug 18, 2019Guide
Mfr/Model: No switch exists between the RBR50 and RBS50s. All wired devices connect to a TP-Link 24p unmanaged switch, and the switch is connected directly to a LAN port of the RBR50. Both RBS50s were connected directly to RBR50 LAN ports.
Daisychain: Yes I had it enabled (checkbox ticked).
Size of home: 2250. RBS50-1 and RBS50-2 are both about 35ft with intervening walls. CAT6 path is obviously longer.
Storms: I have IP reservations for the RBS50, set to .2 and .3. I don't believe there are any IP conflicts; everything is DHCP; and I have about 6 total reservations defined.
Bear in mind, this system was working fine for many days (maybe 1 weeks?) after the FW upgrade. But at some point, downstream bandwidth dropped dramatically (upload speeds not affected), and ONLY on devices connected via WiFi to either RBS. The condition remained this way constantly. When I forced a WiFi connection to the RBR, it's bandwidth was NOT affected, nor were any of my wired devices, in either upstream or downstream.
BTW I did the FW upgrade while in the wired backhaul configuration, and did not do any special manual power cycling/resetting. I understand that you advocate the brute force wipe everything clean method but I did not do that.
At the moment I've got the wired backhaul disconnected and I've rebooted a couple times. Switched off daisychain also. Apparently I don't need it, since my backhaul status still shows "GOOD" on WiFi. No issues seen at this point with WiFi backhaul.
ekhalil
Aug 18, 2019Master
- HTBruceMAug 18, 2019Guide
Ekhalil & FURRYe38 - I may give those steps for wired backhaul a try when time permits. But it's doubtful I'll be able to try without the TP-Link switch since so much of my network depends on it. Plus I have no idea how long it takes for the degradation to occur and cannot live without full network until that time.
Honestly I think this router just knows how to get under my skin, and I don't want to turn this into a career. I'm retired from the tech industry and not really excited about beta testing :smileyhappy:
