HTBruceM's avatar
Aug 17, 2019
What happened to my posting
I posted then edited the posting with a different title and it disappeared? https://community.netgear.com/t5/Orbi/Sat-WiFi-downloads-slow-to-kilobits-s-with-wired-backhaul/td-p/1789011 I spent a lo...
  • ekhalil's avatar
    ekhalil
    Aug 18, 2019
    HTBruceM wrote:
    I REALLY need some stability in the network because I'm planning to drop my Dish Network and switch to YouTube TV streaming service in the next month, so even TV viewing will then be dependent on internet access. Technically I don't even really need a mesh system because I've got the CAT6 wiring I need to just use APs. Whatever; this is where I am right now.
    I have a very stable and robust wifi network currently with 2.3.5.30. All I needed to do related to wired backhaul is mentioned in this post: https://community.netgear.com/t5/Orbi/Wired-Backhaul-in-recent-firmware-releases/m-p/1783871#M67538
    This should not e difficult to do to fix your issues and improve your system.
