mor10
Dec 01, 2023Aspirant
What happened to the log and Attached Devices
What happened to the log and Attached Devices. I had my router set to email me the list of attached devices every morning, but a couple of weeks ago it stopped including this list. What changed?
- Dec 01, 2023
Sorry, misunderstood the question. After I had responded, I realized that my router is not getting the latest version when I ask it to check it self, so I did a manual check and found I was way behind. I have now installed 2,7,5,4, and I can see attached devices in the log again.
Problem solved.
Thanks.
Dec 01, 2023Guru - Experienced User
Does the router reporting any errors in emailing the logs to your email address.
Select the SEND NOW button in the log area then look at the results to see if there is any problems.
What FW version is loaded?
What Orbi model do you have?
CrimpOn
My RBR50 stopped sending log files when v2.7.5.4 was released in Feb, 2023. I can send a log manually, but the automatic send function no longer works. Here's my setting:
I was a wee bit annoyed, having collected every log entry for four years. Was fascinating to see how the various DoS entries changed over time. Oh, well. Gone. Not coming back. Get over it.
