mor10
Dec 01, 2023Aspirant
What happened to the log and Attached Devices
What happened to the log and Attached Devices. I had my router set to email me the list of attached devices every morning, but a couple of weeks ago it stopped including this list. What changed?
- Dec 01, 2023
Sorry, misunderstood the question. After I had responded, I realized that my router is not getting the latest version when I ask it to check it self, so I did a manual check and found I was way behind. I have now installed 2,7,5,4, and I can see attached devices in the log again.
Problem solved.
Thanks.
mor10
There are no errors logged. I have Known DoS disabled, so the only thing it typically sends are [remote login] and [Time synchronized with NTP server].
I have not made any changes to the internal firewall of the Orbi RBR50, so whatever it came with is still there.
Dec 01, 2023Guru - Experienced User
What FW version is loaded?
- mor10Dec 01, 2023Aspirant
Problem solved.
Thanks.
