wilber87
Oct 03, 2018Aspirant
What if a mesh wifi access point reaches maximum connections?
What if a mesh wifi access point reaches maximum connections and a new device wants to join the network at the location of that access point? Will the device be switched to the other access point aut...
Oct 04, 2018Guru - Experienced User
How many devices do you have connected total?
wilber87 wrote:
What if a mesh wifi access point reaches maximum connections and a new device wants to join the network at the location of that access point? Will the device be switched to the other access point automatically?
wilber87
Oct 04, 2018Aspirant
FURRYe38 I want to have about 50 devices connected to 1 access point. If there's a 51st device wanting to join the network, I will want it to be connected to the other access point in the same mesh network. Is that possible?
- rhester72Oct 04, 2018Virtuoso
Very short answer - no. Slightly longer answer - you wouldn't want it to be anyway, because the signal strength (in a proper install) will be much poorer on the other AP.
The number of connected devices is entirely irrelevant (you can literally have thousands of STAs), it's merely a question of *simultaneous and unidirectional* bandwidth utilization.
Odds are, if it _is_ a saturation problem, the backbone is already saturated anyway and it really won't make a whit of difference which AP you connect to, as they will all be equally bad.
- FURRYe38Oct 05, 2018Guru - Experienced User
50 is alot to have connected to 1 AP. It's recommended to have more than 1 AP source and spread the device connections across each AP for best operation and performances.
