JoeM845
Dec 28, 2019Luminary
What is current public firmware for RBK50?
I am running 2.3.5.30 on my RBR50. The device's check for update says "No new firmware available". The downloads page shows 2.5.1.8 as the current firmware. I am confused.
What are the release statuses that Netgear goes throuhg? Is 2.3.5.30 stable enough for the public to do manual updates, but not stable enough to allow automatic updates?
Am I missing something else here?
Thanks,
Joe
Sort By
- JoeM845Luminary
JoeM845 wrote:...
Typo correction. Could not find an edit option.Snippet should be
"What are the release statuses that Netgear goes through? Is 2.5.1.8 stable enough for the public to do manual updates, but not stable enough to allow automatic updates?"
- SW_Prodigy
JoeM845 wrote:"What are the release statuses that Netgear goes through? Is 2.5.1.8 stable enough for the public to do manual updates, but not stable enough to allow automatic updates?"
It depends on your setup. It's stable on my setup, but might not be on yours. If things are currently working fine on your setup, just wait for auto update. Otherwise, check out this thread before upgrading to v2.5.1.8 manually.
