kayton's avatar
kayton
What is maximum number of satellites for RBK852 or RBK854?
I am trying to cover a 7000 square foot multi-story building.  What is the maximum number of satellites than an RBK852 can handle?  Or is there a different system (like Nighthawk mesh) that might work better?  I need 1 Gbps or higher.  Thank you.
  • FURRYe38's avatar
    Confirm this model number of RBK452 and 454? Is this Orbi or Nighhawk?
    There a web page for this series?
  • CrimpOn's avatar
    CrimpOn
    Oh,dear. RBK452 or RBK454 are not Netgear model numbers.
    It makes a world of difference what kindof 7,000 sq. ft. multi-story building this is.
    (7 floors of 1,000 sq. ft. each?  2 floors of 3,500 sq. ft?)
    and how the building is constructed.  Typical office building with concrete/rebar floors? Residential wood frame?  Warehouse?
    If you post the question in the Orbi "AX" forum, someone may report the number of satellites they have added to one AX router:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    • FURRYe38's avatar
      I would confirm model # first. There is only Orbi 7 and 850 series systems. I don't see any 4 series Orbi AX listed. Possible this is a RBK40 series?
    • kayton's avatar
      kayton
      Thanks - I posted in AX forum.  House is multi-story with stone and cinderblock walls, so I will need many satellites.
      • CrimpOn's avatar
        CrimpOn
        Exterior walls simply reduce the impact on your neighbors.  Interior stone and cinderblock walls are horrible for WiFi coverage.
