Shotround
Jan 26, 2019Apprentice
what is orbi's tcp session timeout value?
does anybody know orbi's tcp session timeout value? my guesstimate puts it somewhere around 5 or 10 minutes.
Feb 15, 2019Guru - Experienced User
And when you put the Orbi in place of the Linksys and in router mode is when you do see problems.
Does the modem from the ISP use DHCP or PPPoE to connect to the ISP services?
Shotround
Feb 15, 2019Apprentice
And when you put the Orbi in place of the Linksys and in router mode is when you do see problems. i wouldnt be posting if there were no problems.
Does the modem from the ISP use DHCP or PPPoE to connect to the ISP services? some variant of dsl, likely vdsl. while it supports that, it is not something the user can select.
