kady
Dec 26, 2019Follower
What is the best Modem to use for 1GB Suddenlink service? I have ORBI routers AC3000.
What is the highest performance modem I can purchase for Suddenlink 1GB service? I have an ORBI AC3000 router, but also looking at the new WiFi6. Thanks for the advice.
Dec 26, 2019Guru - Experienced User
What ever the ISP supports will be suggested. Modem with out a built in router as well is recommeded.
NGs CM1000 or CM1100 or CM1200 would be recommended. If you ISP supports them. You'll have to ask them about those models.
