Ragar99
Apr 05, 2019Luminary
What is the best Orbi Firmware if you are using AP mode?
Orbi RBR50/RBS50 Firmware Version 2.3.1.44 is another NG train wreck. How they keep screwing up is beyond me.
Regardless I saw an early poster in the 2.3.1.44 thread say they had gone back to ...
Ragar99
"all I care about is wifi speed and device support. "
SW_
Apr 05, 2019Prodigy
The biggest issue folks have with v44 is connectivity, not download speed. Unless you have a specific problem with v44 in your setup, max download speed shouldn't be an issue since it's relatively close to previous release such as v210. You won't likely notice any difference in normal daily usage.
Give v44 a shot and draw your own conclusion. If v44 doesn't work for you, then stick with your current version until the next one comes out.
- Ragar99Apr 07, 2019Luminary
v44 was what started this thread, speeds/range dropped, which is why for me it is a train wreck. Went back to v210 and blocked updates.
- FURRYe38Apr 07, 2019Guru - Experienced User
Ok.
One thing I am noticing is that one of my wirelss bridges keeps stoping when connected to the RBS in the next room.
