slate2000
Jun 07, 2018Tutor
What is the difference between Orbi SRK60 and Orbi RBK53? They have same hardware specs....
SRK60 v. RBK63
They have the same hardware. What are the actual differences? Why would I buy the SRK60 when the RBK53 does same work?
Thanks
- Jun 08, 2018
Thanks St-shaw! I didn't look at the features only the hardware. They seem identical from a hardware perspective when I campared the spec sheets. I don't need the Pro version.
st_shaw
Jun 08, 2018Master
Did you look at the product pages for Orbi and Orbi Pro?
The pro has different packaging, and wall mount brackets. Orbi Pro has completely different firmware, providing three isolated WiFi networks. Some say the network isolation on Pro is better than the home Orbi. Some say the Pro is more robust and reliable. I've had no issues with my non-Pro Orbi, so I don't know if that's true.
I suspect the internal hardware is virtually identical between the two, with the firmware providing the differences.
slate2000
Jun 08, 2018Tutor
