ryanpc
Mar 21, 2019Guide
What is the latest firmware I should be running on my RBR50?
Current firmware 2.2.1.210 (says there are no updates)
From netgears page however it appears there is version 2.2.1.212 and 2.3.0.32 available
Any help is appreciated
Chuck_M
Mar 21, 2019Mentor
.32 is current version, but you must first load the intermediate firmware that you identified.
The update service inside of Orbi is not reflecting these newer versions yet as they are manual updates only.
Do your satellites first, then your router.
- ryanpcMar 21, 2019Guide
Should I just wait for the auto update in your opinion? I don’t really care much for new features but obviously want to have the latest security patches
- CrimpOnMar 21, 2019Guru - Experienced User
If you are not seeking a solution for specific problems with Orbi, there is no need to perform a manual update. Netgear receives reports of "issues" with products and their engineers work on changes to the firmware to address those concerns. At some point, they decide their efforts need to be exposed to a test audience, so they release a "Beta" version to a select group of adventurous users. If that test seems to go well, they publish the firmware so others can perform a manual update. A number of people on this community forum have concluded that the "32" firmware solves their problems. As one might expect, a number of people have concluded exactly the opposite: i.e. the "32" firmware is worse than the "210" and they have gone back. At some point, one of two things will happen: Netgear will decide to push an automatic update to all Orbi devices OR they will decide that "32" is not good enough and they will come up with more code changes and go through the process again.
I am happy with "32", although I didn't have any serious issues with "210", either.
"If it ain't broke, don't fix it."
- FURRYe38Mar 22, 2019Guru - Experienced User
We also seen various issues appear when systems are autoupdated. Usually a factory reset and setup from scratch resolves these oddities. I prefer to manually download files and install them my self. Remmber, RBS needs to be updated first then the RBR lastly. RBS can go directly from v210 to v32. The v212 has to be applied first before v32 can be applied on the RBR.
- Chuck_MMar 22, 2019Mentor
Since my previous comment above there has been yet another firmware release that updates the .32 version to 2.3.1.44.
The list of things it claims to resolve are pretty significant, so although you may THINK you are not having issues, your performance and reliability would increase by going to the newest.
You still have to manually get to .32 as is previously described and then have it update to .44
Some may say if it aint broke, dont fix it, but in this case I think it is very much worth the effort.
