ryanpc
Mar 21, 2019Guide
What is the latest firmware I should be running on my RBR50?
Current firmware 2.2.1.210 (says there are no updates)
From netgears page however it appears there is version 2.2.1.212 and 2.3.0.32 available
Any help is appreciated
Chuck_M
Mar 22, 2019Mentor
Since my previous comment above there has been yet another firmware release that updates the .32 version to 2.3.1.44.
The list of things it claims to resolve are pretty significant, so although you may THINK you are not having issues, your performance and reliability would increase by going to the newest.
You still have to manually get to .32 as is previously described and then have it update to .44
Some may say if it aint broke, dont fix it, but in this case I think it is very much worth the effort.
SeaMonkey80
Mar 22, 2019Apprentice
where are you seeing the .44 release, in the GUI or online? also, any chance you can list the changes vs .32? I do not see the .44 on the netgear firware update website for the RBK53. thanks
