Platty
Feb 24, 2022Aspirant
What is the Max voltage input to Orbi LBR1020 router - Can I run it from a 12v car (13.8v) battery
Hi
Please can anyone tell me what the Max input voltage is for my ORBI LBR1020 router.
I ask as I want to run it from a Car Battery Solar system, the baterry Float charges at 13.8v.
Not sure if anyone has done this before, sometimes on this type of equipment you can have a input voltage between 18 - 9 volts and it still works.
Kind regards
Keith
1 Reply
I'm sure there's a little wiggle room in there but I wouldn't be the one testing it with that expensive of a device.
I know they make voltage regulators that'll take higher voltage and drop it down to the desired voltage for pretty cheap.
