HHS9's avatar
HHS9
Follower
Aug 05, 2019
What is the router in the Orbi RBK50 vs RBK50V systems
I'm looking to buy Orbi system.  On the website, the RBK50 system shows it contains router RBR50v2.  The RBK50V (voice activated) shows it contains router RBR50 (ie no version indicated).  Therefore is the RBK50V system using an older router version ?  Can anyone advise as that makes no sense to me.
  • CrimpOn's avatar
    CrimpOn
    The product Data Sheet shows that the router is the RBR50 and the satellite is the RBS40V (which might stand for "Voice")
    https://www.netgear.com/images/datasheet/orbi/RBK50V_DS.pdf
    If it were me, I would probably add an Alexa capable speaker which connects over WiFi to the Orbi and can be located wherever is most convenient.  (Actually, I have no "smart speakers" at all, so that's no true.)
  • FURRYe38's avatar
    Might ask a forum moderator for the specifics...
    Blanca_O
