Appleuser2000
Jun 21, 2020Guide
what is VLAN/bridge and should I enable it?
I noticed at the bottom of the advanced page there is an option called VLAN/Bridge group. What does it do and should I enable it?
Appleuser2000
Jun 22, 2020Guide
my internet seems to work fine but i thought if i enable it i might squeeze better performance from my ISP
Jun 23, 2020Guru - Experienced User
Usually any more processing can impact performances. You can try and see, if nothing seems to make anything better or a problem appears, disable it.
