rampi
Jun 25, 2020Guide
What speed should I expect when connected to the satellite
My Setup: RBR50, RBS50 and 2 x RBS20. RBR50 is connected to a 8-port TP-Link Gigabit Ethernet Switch. And the 3 satellites are connected to the switch with Cat 6E cable. All running firmware V2.5...
- Jun 25, 2020
Glad to hear it was a simple fix!
If you mark it solved it can potentially help the next person as well as others aren't going through the thread trying to fix the problem again :)
rampi
Jun 25, 2020Guide
Maybe it could be the cabling... will check over the weekend and update.
Jun 25, 2020Guru - Experienced User
check your switch too. Maybe its not negotiating a 1gig connection and is only connecting at 10/100mbps.
What speed do you get directly off the satellites ethernet port? That takes the wireless out of the equation
- rampiJun 25, 2020Guide
Will check that. Thanks.
Wonder if there's a way on the Orbi either in the web interface or in the telnet to check what speed has been negotiated on the ethernet interface.
- plemansJun 25, 2020Guru - Experienced User
log into the orbi and then go to advanced----->show statistics.
i screen snipped mine and linked on here.
Indeed that was problem.
The cable connecting the Orbi router to the switch was a Cat 5 cable - it was in 100 Mbps.
I changed it to a Cat 5e and it is all fine now.
Initial test is looking good. Will check a bit more and update.
Thanks for the inputs.
