christianjb
Aug 10, 2019Aspirant
What the Hell is a Dos Attack
I have an orbi rbr 50 as my router connected to an xfinity modem, we have the fastest internet available from them yet I get constant slow downs when downloading from any game service many times. The...
christianjb
Router has the latest firmware, V2.3.5.30, and the isp modem is the Xfinity xFi Advanced Gateway and the model # is: CGM4140COM.
Aug 10, 2019Guru - Experienced User
Modem/Gateway Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- christianjbAug 10, 2019Aspirant
My orbi router is currently on router mode and the modem is already in bridge mode with wireless turned off, should I still turn on AP mode?
- FURRYe38Aug 10, 2019Guru - Experienced User
Can try this. Would mean that the modem would not be passing thru any DDOS attacks and not be come the attacked unit.
See if this changes anything...something to talk to your ISP about. See if they can give you a different WAN IP address.
- christianjbAug 10, 2019AspirantI turned on ap mode and now wifi hasn't been working for 5 minutes now
