arifadihaini's avatar
arifadihaini
Follower
Apr 29, 2017
What the Processor for both orbi RBK50 & RBS50
Hi 1- What the Processor for both orbi RBK50 & RBS50? 2- Does Orbi support 4k streaming and online gaming? 3- can add more than one satellite? Thanks
  • peteytesting's avatar
    Apr 29, 2017
    arifadihaini wrote:
    Hi
    Thanks
    the cpu is Qualcomm IPQ4019
    yes it can do 4k and online gaming
    you can use up to 3 sat's with the 1 orbi router although you would need a very big house to need that much wifi , they need to be about 10-15 meters apart and the orbi router needs to be in a central location as the orbi system run in a star topology not as some believe a mesh topology
