RayanSF's avatar
RayanSF
Tutor
Jul 12, 2017
What will happen to the wifi backhaul when Ethernet is supported?
When the Ethernet backhaul becomes supported what will happen to the high speed band that's already used for the backhaul, is it going to be idle? Because that would be a waste. I think it should be utilized to boost the wifi signal.
1 Reply
  • who knows what will happen at this stage , but it wont really boost the wifi signal , at best it just gives you a second 5 gig band that you may use or not depending on how many dual band wireless ac clients you have
