ekhalil's avatar
ekhalil
Master
Sep 22, 2018
Whay to use only channel 108 for backhaul
I can see that my Orbi system is always using channel 108 for the backhaul network.
I have a neighbour who also has an Orbi system and I can see that his system also uses channel 108 for backhaul and I see that his signals are quite strong at my house (RSSI -71 and -80 dBm).
I'm sure that our networks are distrubing each other and I think this is one of the issues that makes my backhaul not stable.
It should be wise that Orbi either automatically chooses a free channel (there are many other unused channels to choose from!!!) or let us choose a channel (probably not allowed to be selectable in Europe).
1 Reply
  • Anyone sees the same behavior? Which channel does your backhaul uses? Does it change with time and based on surrounding radio?
