desmo-dog
Sep 09, 2018Initiate
When are we going to see new firmware. Is it going to help?
I've been living with the pleasure and pain of Orbi for almost two years now. Although it is very fast and mostly works, it is still (!!!) not really reliable. Is the new firmware going to fix this o...
Sep 10, 2018Guru - Experienced User
NG or any other router doesn't post when FW will be forth coming. It just appears so you'll have to keep an eye on there support download site for yoru model Orbi. Can be anything from 6-9 months in between released from what I've seen.
NG has a new beta available for users to try and encourage users to give it a try:
What do you mean by not reliable? Would need more details...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- desmo-dogSep 22, 2018Initiate
I've been on this board for two years and I've tried everything you've suggested. Even if any of it had worked, it would be pretty sad if all that was necessary. It is 2018. The first thing that needs to happen is that it needs to work--then we can tweek it to make it better. We are way past the point where it is okay to expect that we need to get into the technical weeds just to just make it work reliably. Someone at netgear needs to do their flippen job to fix this so that we don't have to have furrye38 trying to fix everyone's problems.
- michaelkenwardSep 23, 2018Guru - Experienced User
Which Orbi device are we talking about here? What is its firmware? And what is the "modem", or whatever it is that connects the router to the internet?
Without this information, no one is in a position to answer your questions.
- FURRYe38Sep 24, 2018Guru - Experienced User
Have you tried some of the suggestions? Been helpful for others. it's not always a FW issue.
If you tried the suggestions and can't get your system running, then you need to contact NG support. You may have a bad system that needs to be RMAd.
